looking for a good steam contractor
adamdivine
Member Posts: 8
Any "steam heat pro's" that service northwest New Jersey? I am looking for someone to come to Belvidere NJ. I have a one-pipe system that needs some pipe run for a relocated radiator and a new radiator. The two radiators were taken off the system before I purchased the house and I would like to add them back in. I am having trouble locating someone to do the work who is really good with steam. The guys who are local are the same ones who had the system set at almost 3 psi when i moved in! I just want someone who is experienced with steam to work on the system. Any help would be appreciated! Thanks.
Look in the Find a contractor area
right here on the website. Just enter your zip and give yourself a couple hundred mile radius.0 -
using the search tool
are the contractors that are found by using the search tool vetted in any way? I guess I just want to make sure that the company I would be calling is really an "expert" when it comes to steam radiators. I was also trying to see if anyone who might be in my general area had any recommendations. Thanks.0 -
I don't know
if they are vetted. Likely someone will contact you through this discussion.0 -
I will wait for further responses0 -
What is your zip?
I'll type it in there myself and see if I recognise anybody.0 -
zip
is 078230 -
I didn't recognise any of the names.
I guess everyone is out there working. Someone will contact you eventually.0 -
Is this the area
known as the Jersey Skylands?
We've gone there for steam, if you can't find anyone local.
http://www.heatinghelp.com/forum-thread/131004/ARCO-Model-K-system-in-the-Jersey-SkylandsAll Steamed Up, Inc.
Consulting0 -
yes
This is in the same area. I called and left a message for you.0 -
Got it
we're working on a boiler replacement today and didn't get your message until late. I'll try to call tomorrow.All Steamed Up, Inc.
Consulting0
- 120 Geothermal
