L608A vaporstat hi low fire set up
clammy
clammy Member Posts: 3,242
How succesful has any one been using them for hi low fire control ?any real issues i should be aware of before i set out to use it for a hi low fire set up ,thanks for any input peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
    Steamhead Member Posts: 18,213
    If it's the usual setup
    where the Vaporstat breaks the circuit to drop the boiler to low fire, it will work fine.
    Consulting
  • JStar
    JStar Member Posts: 2,752
    Ahh.
    I was just thinking about this concept the other day. Made a post about it. Figures, it already existed somewhere.
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    W-M Option
    Weil-McLain uses the setup you describe as on option on its LGB model boilers.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • JStar
    Hmph.
    Well, at least I know it's a good idea. For whatever that's worth.
