L608A vaporstat hi low fire set up
clammy
Member Posts: 3,242
How succesful has any one been using them for hi low fire control ?any real issues i should be aware of before i set out to use it for a hi low fire set up ,thanks for any input peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
If it's the usual setup
where the Vaporstat breaks the circuit to drop the boiler to low fire, it will work fine.All Steamed Up, Inc.
Consulting0 -
Ahh.
I was just thinking about this concept the other day. Made a post about it. Figures, it already existed somewhere.0 -
W-M Option
Weil-McLain uses the setup you describe as on option on its LGB model boilers.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Hmph.
Well, at least I know it's a good idea. For whatever that's worth.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
