Uponor Manifold & Brain Cramp!
Kungur
Kungur Member Posts: 49
I installed an Uponor manifold this Spring during a remodel project and it is now time to tie my Pex supply & return into it. The problem is I cannot rememeber which part of the manifold is the supply and which is the return! It is a vaveless  & the other half has balancing valves.
Would appreciate your help!!
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Valves...
    are usually on the return manifold.
    ME
  • pipe4zen
    pipe4zen Member Posts: 108
    which manifold?
    The newer EP manifolds have flow meters on the supply, the caps are the return, remove caps for actuatores if using.
