Uponor Manifold & Brain Cramp!
Kungur
Member Posts: 49
I installed an Uponor manifold this Spring during a remodel project and it is now time to tie my Pex supply & return into it. The problem is I cannot rememeber which part of the manifold is the supply and which is the return! It is a vaveless & the other half has balancing valves.
Would appreciate your help!!
Valves...
are usually on the return manifold.
ME0 -
which manifold?
The newer EP manifolds have flow meters on the supply, the caps are the return, remove caps for actuatores if using.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
