LWCO
ottawan
Member Posts: 14
I need a new LWCO (Mcdonnell & Miller , #341600, strainer, valve etc kit) and I see I can buy it on-line from Radwell International for $186. Is installation (apart from the piping) just a matter of putting it back in as it was or are there fine adjustments to be made to ensure proper operation once it's in? That is, could a DYI type who has done some copper piping handle this?
use the force
not sure which model u have:
http://www.mcdonnellmiller.com/MM-Installation-Instructions.aspThere was an error rendering this rich post.
Model Number
Tom
I've attached a few pictures of the part and a label on the piece above it showing the model number of the whole control (I think). Hope this helps.0 -
you may want to look...
at StateSupply.com as well for MM repair parts. http://www.statesupply.com/displayCategory.do?Id=765
Make sure that you get the necessary gaskets if applicable.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Parts
Thanks for the tip on Stateside. Nicely organized site.0
