Pilot light and flame questions
bennythepitbull
Member Posts: 37
in Gas Heating
I have a Crown -- JSI172 6" flue BTU in 172,000 out BTU 140,000 438 sq foot.
my pilot has three outlets it fans about about 3" wide and about 2"
high. The heat is enough to prime about 2' of a 3' rise in the b vent
system. To me this seems like a big pilot (you can rally hear it) but I
never checked it until now. I had to move my furnace recently but the
gas lines overall length is still pretty close to what it was. After
firing the boiler the flames seemed very high like 4-5 " high and very
yellow IT was almost like a halo surrounding the tops of the flames. I
turned down the pressure adjustment and this solved the high flame issue
however the pilot is still as big as it was before the adjustment. So
is this pilot just par for the boiler.
I should note
there was plenty of blue in the flames it was the tips that were yellow
with a whitish ring ( the halo around the top) The pilot is all blue
IN addition here is my boiler.
<a href="http://www.crownboiler.com/products/res_gas/jam3_prn.asp">http://www.crownboiler.com/products/res_gas/jam3_prn.asp</a>
I should note
Are you a professional?
If not this is way more than you should be attempting. Call a professional gas technician and have them determine if the boiler is firing correctly and if the pilot is okay. They can also do a combustion analysis and bring your boiler up to peak efficiency.
What is your location?0 -
I live in NE PA
Should I just call UGI -- And the reason I would like to know is so I know the work that is being done is done correctly. My flames for my boiler mostly blue with some orange mixing in. the pilot is all blue. So any pointers or an online reference guide would be great. My issue with the pros is a pro installed this boiler into a 100 year old chimney with no liner -- although he did suggest it he did it any way because cost was a concern. This left us thinking that it still was okay. As you may have guessed the chimney rotted.0 -
There is the very real possibilitiy
that you may be having high carbon monoxide issues. Get a professional to look at this immediately.
The main gas through the gas valve is regulated but the pilot is not. The pilot should be adjusted according the specs on the gas valve and the rating plate on the equipment should determine what the manifold pressure should be.0 -
If your techs
are not sure what to do checkout "Resources" above go to "Hot Tech Topics" and look for "Thermocouple Testing Procedures",0 -
I should note
I already moved my furnace and connected it to a Dura vent system. all is well every thing checks out. no steam pipe leaks, no water hammer, I have 10 steam radiators and all are getting hot. MY main concern is my orange tipping when the furnace is on and this pilot light. Thanks for the help0 -
It's impossible to tell
if a flame is burning safely and efficiently by just looking at it. You need a pro with a digital combustion analyzer to verify this.
Now.All Steamed Up, Inc.
Consulting0 -
Benny...
The fact that you did all the pipe work is commendable. This means you are mechanically sound. It does not mean you are technically oriented or technically correct.
As Steamhead has pointed out, you MUST get someone in there with a combustion gas analyzer to make certain that the fire side is in safe and good operating condition. Your gas supplier should be able to send someone out (probably for a fee), but the peace of mind is worth it knowing that you will wake up in the morning.
Congrats on your mechanical aptitude.
ME0 -
could not agree with you more
I already set up appointment with UGI, Thanks all0
