diagram of pumping away
aphco
Member Posts: 13
Other than in the book "Pumping Away", is there a diagram available, on the net, of the proper piping arrangement to pump away. I have done a search of this sight and googled it, but I must not be wording it correctly.
Does any one know where a good sketch or diagram can be found?
Diagram
Try this attached pdf.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
