Richmond Floorline Radiators
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,686
Baseboard from 1929. I just added this to the Library.
<a href="http://www.heatinghelp.com/article/158/Radiators/1818/Richmond-Floorline-Radiator">http://www.heatinghelp.com/article/158/Radiators/1818/Richmond-Floorline-Radiator</a>
Retired and loving it.
  • Brad White
    Brad White Member Posts: 2,399
    Precedence
    "Precedence is no longer a master. Almost every day sees a convention, thought to be enduring, surrendering to improvement."
    And that is how the brochure starts...
    Man, could they ever write!
    Kind of brings a tear to your eye, does it not?
    Seems you tapped a vein of knowledge again, Dan. Performing apheresis from Dead Men no less.
    Thanks as always.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • DanHolohan
    Beautiful indeed.
    I'm having fun rummaging through the stacks.
