Richmond Floorline Radiators
DanHolohan
Member, Moderator, Administrator Posts: 16,538
Baseboard from 1929. I just added this to the Library.
<a href="http://www.heatinghelp.com/article/158/Radiators/1818/Richmond-Floorline-Radiator">http://www.heatinghelp.com/article/158/Radiators/1818/Richmond-Floorline-Radiator</a>
Retired and loving it.
Precedence
"Precedence is no longer a master. Almost every day sees a convention, thought to be enduring, surrendering to improvement."
And that is how the brochure starts...
Man, could they ever write!
Kind of brings a tear to your eye, does it not?
Seems you tapped a vein of knowledge again, Dan. Performing apheresis from Dead Men no less.
Thanks as always."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Beautiful indeed.
I'm having fun rummaging through the stacks.Retired and loving it.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
