threader chewing up threads
sjb
Member Posts: 3
has anyone had problems w/ their threader chewing up threads? I have a ridgid
700 power threader w/ a 3/4" die that will destroy the 3rd & 4th thread. I just bought a brand new die and it does the same thing. Could be the pipe? It is made in Canada and coming form a reputable wholesaler
pipe dies
having the same issue and not just with 3/4". IF you properly reset your dies when you replaced them and are using fresh oil and the problem continues, its got to be the pipe.....frustrating when we spend 1/2 day looking of die teeth (Ridgid selling at HD for under fair trade and our supplier has stopped carrying the parts, at least that is the excuse we hear) and the new teeth do the same thing......grrrrrrrrrrrrrrrr0 -
Bad oil...
I've seen cheap and bad cutting oil cause the threads to spall.
Possibly a recent change in oil useage lately???
ME0 -
What Mark said!
Its often the oil. We had an old time who worked for us and he would always complain about the new pipe and how bad it threaded. One day I noticed he was dumping his used motor oil in the threader oil bucket. When he finally was not looking I replaced the oil with fresh clean oil and he commented on how much better the new pipe we got was.Cost is what you spend , value is what you get.
cell # 413-841-6726
Same Problem
It has been happen to us too. Went out and bought a new head. Same thing happened. Replaced oil. Same thing. Pipe was from Canada and seemed to have a thicker wall. My father said same thing happened to them around 20 years ago with pipe from Canada. Now we ask where the pipe is from before we buy it. Supply house looked at us like we were crazy.0 -
Oversize pipe?
Try a new wheel in your cutter.There was an error rendering this rich post.
Pipe threads:
Same here. Some time ago, I had a problem with wrecked threads. Found out it was "foreign" pipe. Started demanding US made pipe and the problem stopped. Seems I remember using 10' lengths with no markings and had a problem. Got a 21' length of US pipe and had no problem.
Before getting too nuts, try some other pipe. Like if you have some old salvaged pipe of left over short pieces. Try threading them. If you don't have a problem, it's the pipe. That's how I figured my problem out.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
