Radiant heat under ice rink
steveg
Member Posts: 16
Has anyone had experience with radiant heat under an ice rink to prevent frost buildup in the ground?
What are the design basics I should be aware of?
pex tubing manufacturer assistance
I have recently worked on a project for frozen food cold storage warehouses. Whatever pex tubing you use, use their resources to start. I would like to offer a suggestion, use the "waste" heat from the refrigeration side to heat the ground below with a boiler backup. Paul Rohrs wrote an article (in PHC News I believe) about it and it worked great for my project.
Hope this helps.
http://www.uponor-usa.com/Misc/Applications/Permafrost-good.aspx0 -
Ice Rink
Why not use a chiller that creates glycol to -8C and recovers the heat... free heat COPs go through the roof. Great way to do it. Aermec NRL with heat recovery, now available in North America0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
