New Boiler install
crownboiler
Member Posts: 5
in Gas Heating
HI,
I had a plumbing contractor install a new Crown boiler over the holiday weekend. He removed old American Standard boiler that had a born date of 1948. This a one zone system including the basement.
My question is although this is a one zone system should a flow control valve been installed ?
Do you get domestic hot water from
the boiler? If not with a single zone one circulator the flow control valve is really not necessary. I have seen inspectors require one anyway but really not necessary.0 -
It may be in the new pump?
does it say ifc on the circulator pump?Cost is what you spend , value is what you get.
cell # 413-841-6726
PICTURES
Where's the before & after pictures?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
