Graphite material
radmix
radmix Member Posts: 194
Has anyone had a chance to work with any of the radiant graphite material. Has you found that it works at lower temps than extruded plates alone or any other pros or cons
Rich
  • JohnSweaney
    JohnSweaney Member Posts: 1
    FlexPlate (graphite plates) heat output
    Rich,
    I know you're looking for some real world installer feedback on output but I'd be glad to send you some side by side output comparisons that show FlexPlate gives about 15% more output than extruded alum plates at the same water temp.
    Let me know if I can help.
    John @ Watts Radiant
