Graphite material
radmix
Member Posts: 194
Has anyone had a chance to work with any of the radiant graphite material. Has you found that it works at lower temps than extruded plates alone or any other pros or cons
Rich
Rich
FlexPlate (graphite plates) heat output
Rich,
I know you're looking for some real world installer feedback on output but I'd be glad to send you some side by side output comparisons that show FlexPlate gives about 15% more output than extruded alum plates at the same water temp.
Let me know if I can help.
John @ Watts Radiant0
- 114 Geothermal
