taco rmb question
clammy
Member Posts: 3,242
i was wondering if taco radiant mixing blocks are avaiable with a plate exchanger i thought i saw that they where it would save me a bigger job of installing a plate exchanger i do realize that either way i would have to add a expansion tank feeder and all the stuff but i think it may be cheaper tahnks clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Is their XPB close enough to your needs?
http://www.taco-hvac.com/en/products/X-Pump%20Block%99%20%28XPB%29/products.html?current_category=3740 -
Taco XPB
Expensive, but they save a lot of time.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
