Thermosta Recommendation
Kungur
Member Posts: 49
As I move along with my radiant heat retro project I was wondering about thermostats. Is there a specific kind to use for radiant heating? Any recomendations would be appreciated.
Thanks!
Thanks!
White-Rogers
I used to use the White-Rogers 1F80-0361, but it's been replaced by the -0261. If it's anything like the previous model, it is very reliable, easy to set up and homeowner friendly.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
our go-to
is the Tekmar 509 (a 508 with a floor sensor). if you're going to do radiant I think floor sensors should be standard equipment.Rob Brown
tekmar
I second the tekmar 509 (same as a 508 but packaged w/floor sensor) easy to use, very flexible, built solid and look really clean.0 -
Comfort dials
Oventrope non-electric controls work wonders, are extremely simple and provide the ultimate in comfortJeffrey Campbell0 -
I'm with you Jeffery....
Non electric TRV's in 2/3's of my houses, and when I get around to hydronicing the third, you can bet it will be non electric TRV's.
ME0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
