Nicked PEX
Lee_H
Lee_H Member Posts: 4
One of our contractors was doing a concrete repair and nicked the snow melt pex embedded in the sidewalk.  We will have to clear back enough concrete to get to the piping.  Once there what is the best way to repair this?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    I just did this yesterday...
    I used the Wirsbo ProPex expander with brass barbed coupler.
    Make sure you have enough room to move the tubing around as well as get the tool into the hole.
    In lieu of the ProPex expander, you could use a Watts crimp ring assembly. But you will still face the same issues of tubing free play, as well as being able to get the tool into the hole.
    I now know how my dentist feels.. I promised the custoemr I would keep the hole to less than 7" in diameter, so he can core drill a 8" plug for replacement (stained concrete).
    Good luck
    ME
  • Lee_H
    Brass protection
    Mark, Did you do anything to protect the brass from concrete contact after patching?
  • Mark Eatherton
    Not much brass exposed...
    but 2 wraps of mill tape should cover it.
    ME
