new compressor with older freon?
Dave_61
Member Posts: 316
Our Lennox central air unit died (needs a new compressor). The repairman came and we need a whole new unit as the older freon is ozone depleting. Are there still parts available that are compatible with the older freon? Aren't they able to capture the freon from the unit and just reinstal it in the new compressor so we don't have to spend $4000? We did not have a freon leak, so I assum it is still fine.
Thanks.
Dave
Thanks.
Dave
Dave
YES ,compressors are available for the old r22 unit.Either O.E.M. or by compressor mfrg's that make the comp for many of the A.C. mfrg's anyway.So if a Copeland Compressor was installed in place of the OEM comp then some repiping ,remounting,rewiring will be necessary.Why did the dead comp die?What is the phyical condition of the evap&cond units? Any extra work /repairs would not be included in the price of "change the compressor" ,I would think ! So check out the entire system and then decide . A new hi SEER system saves $$$$ .0 -
He said
the compressor shorted out. It is only about 9 yes old.0 -
Hay Dave.
Me,Myself & I ,we, all agree that compressors should last 15-35 years ,so, what exactly did the under aged comp die from? Some causes are obvious, some have to be observed while the new comp is up and running then adressed.0 -
Not sure.
The wife was there today and said that he said we had a short that somehow affected the compressor, wrecking it.0
