Thermosta Recommendation
Kungur
Kungur Member Posts: 49
As I move along with my radiant heat retro project I was wondering about thermostats. Is there a specific kind to use for radiant heating? Any recomendations would be appreciated.
Thanks!
  • White-Rogers
    I used to use the White-Rogers 1F80-0361, but it's been replaced by the -0261.  If it's anything like the previous model, it is very reliable, easy to set up and homeowner friendly.
  • NRT_Rob
    NRT_Rob Member Posts: 1,013
    our go-to
    is the Tekmar 509 (a 508 with a floor sensor). if you're going to do radiant I think floor sensors should be standard equipment.
    Rob Brown
    in beautiful Rockport Maine.
  • zacmobile
    zacmobile Member Posts: 209
    tekmar
    I second the tekmar 509 (same as a 508 but packaged w/floor sensor) easy to use, very flexible, built solid and look really clean.
  • Simply Rad
    Simply Rad Member Posts: 195
    Comfort dials
    Oventrope non-electric controls work wonders, are extremely simple and provide the ultimate in comfort
    Jeffrey Campbell
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,872
    I'm with you Jeffery....
    Non electric TRV's in 2/3's of my houses, and when I get around to hydronicing the third, you can bet it will be non electric TRV's.
    ME
