Daikin altherma air to water or gshp
tim smith
Member Posts: 2,876
What ye all think, I saw the altherma the other day and talked to some guys who have installed a few. They think highly of them. Any opinions appreciated. Tim
depends.
how much is the dirt work on the gshp?
how big is the heat load... one, or two, or more althermas?
what's your design temp?
for us... ground work prohibitive, 35k load, doing heating and cooling, -4 deg design temp, the altherma was a good choice.
larger loads, pump and dump, colder areas, might want to look at GSHP.Rob Brown
RE: design temps etc
24 here in seattle, appx 8 tons needed on job. The well drillers who also set the pump station and run out piping run appx 6-8k per hole. Maybe 8 holes. It would take 2 Daikins to do job. Thanks for reply, Tim0 -
sounds like
the daikin would come in about half price then.
average COP of 3 they say, once you factor in the electric backup usage. Have to compare that to a 4+ you might get with geo I suppose. I'm not yet sold on the average COP of 3 claim when the heat pump is only capable of half output in very cold weather basically... but that is what they say.
With dirt work in the comparison though it's pretty attractive. Heck, you could get 3 althermas and still be significantly cheaper it sounds like?Rob Brown
Altherma great unit with competitors
Hello the Altherma is a great unit but there are options in the air to water field for less dollars.. www.aermec.us0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
