Installing a vinyl pan in shower stall
Hark
Hark Member Posts: 10
I am installing a vinyl pan in a shower stall with a 2" pvc drain line and 2" shower strainer.. I told the tile guy he has to pre gauge floor before I install my vinyl pan. He says you don't have to, why does pre gauge need to be done? What is the improtance of pre gauging?
  • pre gauge floor?
    New-one on me when using a PVC pan liner.
    The strainer usually has an adjustment to alter the depth.
  • Hark
    What is a pvc liner?
  • This may explain,
    typically what I see; http://www.youtube.com/watch?v=EZKL-CIoOEk
  • Hark
    thank you so much
  • Hark
    thank you so much
  • Hark
    thank you so much
  • skifast
    skifast Member Posts: 2
    Alway pitch
    You must per pitch all shower pans the concrete or tile are not h20 proof. The water after about 3 or 4 showers will leach through and the whole pan. If not pitched will be come a cesspool of water do not put in the pan with out pitching it we some times us roof shingles under 1/2" plywood it does not need to be much but you will save your self a lot of trouble down the road.We have ripe out over 20 pans in the last 3 years from poor installations. Good luck.
