Installing a vinyl pan in shower stall
Hark
Member Posts: 10
I am installing a vinyl pan in a shower stall with a 2" pvc drain line and 2" shower strainer.. I told the tile guy he has to pre gauge floor before I install my vinyl pan. He says you don't have to, why does pre gauge need to be done? What is the improtance of pre gauging?
pre gauge floor?
New-one on me when using a PVC pan liner.
The strainer usually has an adjustment to alter the depth.0 -
What is a pvc liner?0 -
thank you so much0 -
Alway pitch
You must per pitch all shower pans the concrete or tile are not h20 proof. The water after about 3 or 4 showers will leach through and the whole pan. If not pitched will be come a cesspool of water do not put in the pan with out pitching it we some times us roof shingles under 1/2" plywood it does not need to be much but you will save your self a lot of trouble down the road.We have ripe out over 20 pans in the last 3 years from poor installations. Good luck.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 967 Plumbing
- 385 Solar
- 15.3K Strictly Steam
