weil series580 steamer 2 stage oil burner?
clammy
clammy Member Posts: 3,255
Was wondering if there is a 2 stage burner for a weil 580 ,weil site does not show that there is one avaiable for this boiler ,i am wonder if any one knows what manafature makes one that will work on a 580.it would be nice to have on this size boiler to stop short cyling plus there is a loop hot water  cast iron baseboard off the botton of the boiler which i know short cyles the boiler when it is the only thing calling.Thanks for any info .Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,425
    No
    580 is only single stage
    cell # 413-841-6726
  • clammy
    had also seem at weil site
    Thanks for the confromation ,but i thought maybe someone had some infromation about a 2 stage unit it really stinks that there is not 2 stage burner for these light commerical boilers until you get to the 680 and above .i would think that there is  a market for 2 stage burners for boilers in this size it would make alot of sense but i guess the big burner co see no point to it but i personally see it as a smart move but then again i have seen so many larger boiler with 2 stage burner that where neither set up correctly or had not had any automatic controls to take advantage of the burner and possible fuel savings with the price of all types of fuel increasing i see it as penny wise and dollar foolish but i also realize that most that where not set up to take advantage of the 2 stage where left with just a switch(hi low) mainly either because the installer had know idea how to install controls to take advantage of it and neither did the supply house and the boiler manafatures kinda leave it all in a gray area ,what a crying  damn shame .Peace and good luck clammy
    NJ Master HVAC Lic.
    Mahwah, NJ
    It is a shame
    The thing is I see so many not set right even on the larger ones I think they do not want to keep their tech support any busier than it is. If the 580 and smaller had 2 stage it would be ten times more burners to be installed wrong. I know if anyone has a 2 stage that would work I have several people who could use them.
    cell # 413-841-6726
    Steamhead Member Posts: 18,498
    edited August 2010
    Guys, you need to call HeatWise
    and speak to Gotham Kamath or his father Dr. Bola Kamath. They do have such a 2-stage oil burner, it has passed UL and is ready to produce. It should be able to handle a pressure-fired boiler like the W-M 80 with no problem. I believe high-fire on this one tops out at 4 GPH, but that shouldn't really affect the boiler's operation. Go here:
    http://www.heatwise.com/oil.htm
    Then choose the Pioneer 2 page. For some reason, the link doesn't work when I put it into this post directly.
    When you get in touch, tell them I sent you.
    Consulting
    If my next wife lets me
    I will name my next son Frank, or maybe Steamhead. Thanks this looks very promising. I will contact them and see when it is going on the market.
    cell # 413-841-6726
    "If my next wife lets me, I will name my next son Frank, or maybe Steamhead"
    Bill or George or anything but Steamhead! ;-)
    You have to be a certain age to remember where I stole that from.................
    Consulting
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    "My name is Sue, How do you do?"
    Johnny Cash
    "Ring of fire" is my ring tone when my ex calls.
    cell # 413-841-6726
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,591
    Charlie
    Mine is "I Walk the Line" That's why I'm still married!
