Convert vacuum steam heat to hot water heat
KenC
Member Posts: 1
I need help to know what the pitfalls of converting a vacuum steam system to hot water could be.
What do I need to look for?
What do I need to look out For that can bite?
And is there any tricks?
Vacuum Steam
Hi- The first question that comes to mind is: "Why on earth would you want to convert a good vacuum steam system to hot water? Vacuum steam systems, if setup properly, are very comfortable and efficient. Where are you located? If it were me I'd have a good steam pro look at you system and advise you. A lot of good ones frequent this board so perhaps we can find one close to you. I'm a homeowner and I almost switched to hot water several years ago before I found this website and learned something about steam heating and I'm now very glad I didn't change over. Vacuum systems are "the Cadillac" of steam heating, Usually these systems just need a little maintenance and a tune up to bring them back to par and this is a much more economical approach than changing over the system and I also think you'd be much more happier with the final result.
- Rod0 -
Read this
for an in-depth discussion of what can go wrong:
http://www.heatinghelp.com/article/11/Hot-Tech-Tips/152/Converting-from-steam-to-hot-water-heat
We don't do these conversions- too much liability.All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
