Convert vacuum steam heat to hot water heat
KenC
KenC Member Posts: 1
I need help to know what the pitfalls of converting a vacuum steam system to hot water could be.
What do I need to look for?
What do I need to look out For that can bite?
And is there any tricks?
  • Rod
    Rod Posts: 2,067
    Vacuum Steam
    Hi- The first question that comes to mind is: "Why on earth would you want to convert a good vacuum steam system to hot water?   Vacuum steam systems, if setup properly, are very comfortable and efficient. Where are you located? If it were me I'd have a good steam pro look at you system and advise you. A lot of good ones frequent this board so perhaps we can find one close to you.  I'm a homeowner and I almost switched to hot water several years ago before I found this website and learned something about steam heating and I'm now very glad I didn't change over.  Vacuum systems are "the Cadillac" of steam heating,  Usually these systems just need a little maintenance and a tune up to bring them back to par and this is a much more economical approach than changing over the system and I also think you'd be much more happier with the final result.
    - Rod
    Steamhead Member Posts: 18,508
    Read this
    for an in-depth discussion of what can go wrong:
    http://www.heatinghelp.com/article/11/Hot-Tech-Tips/152/Converting-from-steam-to-hot-water-heat
    We don't do these conversions- too much liability.
    Consulting
