Low Sulfur Heating Fuel
Tony Massi
Member Posts: 86
in Oil Heating
I was reading in the news paper today that New Yorks Governor signed into law a bill that would require the use of low sulfur heating oil by July 1, 2012.
What does this mean to the oil heating industry? I really don't know much about low sulfur fuel. Does the heating equipment have replaced?
Re: Low Sulfur Heating Fuel
I just spent the day at Brook Haven National Lab (BNL) and this was among our topic of discussions.
1st this will have no adverse effects on the current heating equipment. in fact it should be a plus for those systems. 2nd There are a number of companies that have already been using low sulfur fuel for past several years and they have reported that as a result service calls were reduced and annual maintenance did not take as long to perform as flue passages were found to have less soot or debris in them.
And finally, this may also open the door for the successful use of oil heating condensing boilers. Currently with the higher sulfur, oil heating condensing boilers can prove to be problematic.There was an error rendering this rich post.
This explains
why I am seeing the Casco Bay boiler being advertised more.Cost is what you spend , value is what you get.
cell # 413-841-6726
Viscosity & Flash Point
Will the low sulfur fuel viscosity & flash point change. Also will we have to change to Bio Fuel Gaskets on all filters and will it effect pump seals.0 -
Seals and gaskets should not have any adverse effect from the low sulfur and should not require any special type gasket. With any introduction of bio-fuel it has been suggested that it could effect the pump seal however this is still being tested at BNL and currently Roger McDonald’s feelings are that if it did it would not be an appreciable amount.
As for the flash point and viscosity I apologize I don’t have those numbers.There was an error rendering this rich post.
I was at the BNL meeting also
Real informative day spent at the lab !
From what I remember , ULS drops the particulate emissions of oil on par with natural gas .
There goes the slogan " go gas , go green "0 -
BNL
If I would have known I would have gone to BNL too. I only live 15 mins from there. I interested in the low sulfur fuel and what benefits it has to keep customers from switching.0 -
biofuel
biofuel will effect gaskets andeals. Oil filters are now coming with a warning not to use them with bio blends. Also it acts as a detergent. If you are not currntly trating your fuel with an additive you will have problems wth sludge clogging filters when boi is used.0 -
It Means The Day Will Come
When we will be able to offer our customers products such as this.
http://www.viessmann.com/com/en/products/Oil-fired_condensing_boilers/Vitoladens_300-W.html
http://www.viessmann.com/com/en/products/Oil-fired_condensing_boilers/Vitoladens_333-F.htmlThere was an error rendering this rich post.
- 110 Chimneys & Flues
- 106 Geothermal
- 983 Plumbing
- 387 Solar
