Argo Panel Trim
heatboy
Member Posts: 1,468
It seems that the "new and improved" version of Panel trim no longer has the option of double tier element. Is this true? The 30% extra output would really help.
I haven't found any other manufacturer that offers a double tier option. Has anyone found a manufacturer that does?
Thanks in advance.
Thanks in advance.
2-Tier
Sterling Light commercial (Mestek)0 -
Slant /Fin
Jeff
Slant/Fin has some nice options for high-output baseboard.0 -
Argo
Used to do a lot of fin tube baseboard in the 80's and 90's and I thought Argo was the best board out there. The enclosure seemed to be a thicker gauge steel which was nice.
Baseboard just seems so pre-historic to me now with the European style radiant panels out here now. When customers want to replace their baseboard. I give them options and they usually go with with the radiant panels after they find out the benefits, especially if they have a mod/con with ODR.
They're not always practical because of cost and height limitations, BTU requirements, etc.. I just thought I'd throw that out there.0 -
argo
check out heating edge from smiths environmental they have a two pipe baseboard with all aluminum fin in it. great for use on mod-con boilers, geothermal h/p systems and solar heating systems. can be used on regular boiler heating systems.0
