Cleaning GB142 Fins
FB
Member Posts: 47
in Gas Heating
There are thick white deposits building up between the fins on the bottoms of the heat exchanger tubes of our GB142 boiler. Is there a cleaning solution that will loosen the deposits without damaging the aluminum of the heat exchanger? Any suggestions about cleaning are appreciated. Fred in Lakewood, CO
Is it a leak or has it not had yearly cleanings?
The owners manual calls for an annual cleaning and a combustion testing. Find a professional familiar with Buderus and they can clean it with mineral oil, this needs to be done according to the manufacturers procedure though.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 167 Indoor-Air Quality
