steam drive?
philly_steam_boy
Maybe a small vacuum pump?
What does the name tag say? Where did it come from?0 -
I do not really know.
Since the pressure vessel at the bottom has a gauge glass on it, I inferred it was a boiler.
Now there is a gizmo on the top that is either a motor or a generator. If a generator, most of it could be a (probably one cylinder) steam engine that runs the generator. If it is a steam engine, the cylinder must be inside the boiler. This was done in the early 1800s to keep it from condensing, but never very popular. The rectangular box on top with a lever arm on it looks a lot like the lubricator for the slides where the valve gear and the thing called a crosshead on a steam locomotive would be.
But as I said, I do not really know. I hope the O.P. knows the answer and is just teasing us.0 -
Just a guess...
but is it remotely possible that this thing is a piston type water pump, with a built-in (built around?!) hydro tank to dampen surges? The gauge glass, then, would tell you how much air was in the tank...Br. Jamie, osb
Water Pump?
I think I'm inclined to agree with Jamie in that it's some type of water pump.
I looked over the pictures and have attached a notated picture which might help someone further identify what exactly it is.
"A" - Is the electric motor which is geared to wheel "D" which a fairly large mechanical advantage.
"B" - Seems to be a controller switch box
"C" - Is a heavily counter balanced lever which probably turns on /off the electric motor.
The heavy counterbalance weight on the end of the lever (see other pictures) would probably mean that it was attached to a heavy mechanical train (or strong switches!)
"D" - Geared wheel - drives sprocket chain and reciprocating arm "E". The reciprocating is rather lightweight so is more likely a control lever. The sprocket chain is more likely the driving mechanism.
"E" - Reciprocating arm
"F" - Analog gauge - Has a large red area which I would assume is a warning area for excess pressure.
"G" - Note the "spout" which carries off (water?) leakage. This feature tends me to think that it is some type of water (feed?) pump
The piping coming out of the unit seems awfully small for a water pump so that mean the water exit was below the base flange. I have no idea of how the water sight glass was utilized or the use of the smaller piping and what looks like a regulator(s).
The base has a fair amount of attachment holes so this would seem to indicate that it was water/gas tight attachment.
Any Ideas?
- Rod0 -
where did you find it?
Could it be from a locomotive? it has a lot of "mechanism" that looks more like engine than heating.
What are you going to do with it? Dis-assembling, and re-assembling it may tell more about the application.
hrBob "hot rod" Rohr
Just out of curiosity…
How can you tell that it's not a generator? I almost certainly don't know what I'm talking about (and am looking to learn), but what if D in Rod's diagram gets turned by the steam, which spins A at a high speed, producing electricity, which might be rectified/filtered by B?
I thought I remembered in TLAOSH that larger buildings used to generate their own electricity. I imagine that the demand was low, so maybe a small generator could handle it.There was an error rendering this rich post.
Could Be?
It could be a generator as all a generator (DC) really is, is a electric motor run backward. If it was motor run by steam, it would need some type of speed governor though of course that might be just a missing part. The heavy flange makes one suspect it might be off, as HotRod suspects,.something like a locomotive.
Philly_steam_boy, does the ID plate on the motor controller box have any information? Also what info is available from the analog gauge? Interesting contraption!0 -
I'm sure it's a pump of somesort
Look at the crankshaft, short stroke, so it will produce high pressure and low volume, I wouldn',t be surprised if the water was used to control something as a hydrolic medium. But, what puzzles me is whats inside that is turned by the chain and sprocket on the flywheel side.0 -
I vote for vacuum pump
If it was some sort of generator I would have thought the drive pulley would be much larger on the steam side of the unit?? but what do I know!!!0 -
Steam Drive More Info
This unit was removed from the basement of a row home in South Philadelphia (Grays Ferry Section).
It was attached to a flange with a piece of pipe buried in the floor. About ten inches below the concrete floor there was a solid dome-shaped piece of steel plate attached to the id of the pipe. Inside the vessel, attached to the drive shaft, is a vertical paddle wheel of some sort. This vessel was bolted to the flange at the floor. The electrical looking box seems to be float switch.0 -
Over engineered sump pump?
If the thing is a float switch, could it be an over-designed sump pump?0 -
an early perpetual motion machine
?Bob "hot rod" Rohr
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
