Furnasty takes on a new meaning!
Dave Yates (GrandPAH)
Member Posts: 281
DIY repair gone bad when furnasty bites back!
<a href="http://www.msnbc.msn.com/id/21134540/vp/37634408#37634408">http://www.msnbc.msn.com/id/21134540/vp/37634408#37634408</a>
I would be curious
to find out how he got stuck in the first place. As I try to picture a furnace just what caused him to not be able to get free???0 -
It was a boiler
While the media, and firemen for that matter refer to the unit as a "furnace" and sometimes "cast-iron furnace" it was a cast iron boiler that partially collapsed off its stand, when reaching underneath causing the cast iron block to collapse on his arm, against the jagged and rotted sheet metal, biting into is arm like a jagged saw blade, not allowing him to pull it out under the weight of the cast block and water.
It was the boiler water he drank.0 -
Makes more sense now
Story makes more sense now.0 -
Photos of the boiler
Here are some pictures of the boiler in question. Looks like he got his arm caught between the cast iron sections.
Can anyone identify the boiler make and model?0 -
you HVAC guys are the greatest!!!
Check out this link:
http://www.courant.com/community/west-hartford/hc-trapped-arm-furnace-0612-pictures,0,5769701.photogallery
Automatic TLC Energy in East Hartford, CT installed a new boiler for Jon at no charge! If you look at the pictures, you can see the sections from the old boiler as they took them out of the house. That might help in identifying the beast.
I follow a number of trade forums and so many times, guys are abrupt or even rude to the many folks who aren't in the trades but are interested in them, like me. You guys have always answered my questions and been really gracious and helpful.
Often on this forum, you will see requests for prayers for others, expressions of concern, and collections for those who are going through tough economic times. This incident shows once again what good guys you all are. There haven't been any smart comments or second guesses about what happened to Jon. And now, Automatic TLC Energy has come through with a new boiler. HVAC guys are great!!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
