Small Electric Boilers?
Bart Vaio
Bart Vaio Member Posts: 56
I used to use the Laing EPR heaters for small loads 2-12 KW.  It seems they have discontinued that line, are there any alternatives out there you guys know about?  Ideal load is 3Kw, any suggestions?
  • Kevin Koenig_4
    Kevin Koenig_4 Member Posts: 36
    Laing EPR
    The last I heard is the the EPR units are currently being upgraded to an ECM pump/motor and going through UL or similar third party testing. The tenative availability is this fall. They will be distributed through the B&G sales chanel. I believe the older  induction motor units are still available.  You may try to contact Laing via there web site and pose the question. Good Luck  Kevin.
    amy.flores@itt.com
    hot_rod Member Posts: 26,604
    Same info I heard
    from the B&G folks in Canada. B&G, or ITT has partnered or bought out Laing,
    I did see a Laing booth at the ASES solar show a few weeks ago, however.
    I think B&G has some interesting plans for that pump line.
    hr
  • bob eck
    bob eck Member Posts: 930
    Electric Boiler
    Argo makes a nice electric boiler.
    email me at eckrobert@rcn.com if your local wholesalers can not get them for you I work for a Plumbing & heating wholesaler and we can ship them direct to you
    thanks bob
  • bob eck
    Electric Boiler
    thanks bob
  • bob eck
    Electric Boiler
    thanks bob
    Electro Industries
    out of Minnesota builds a nice one. Also the Thermolec out of Canada.
    hr
  • Bob Flanagan_3
    Bob Flanagan_3 Member Posts: 67
    And so does
    Slant/Fin....LOL
  • mjcromp
    mjcromp Member Posts: 57
    Hot Rod's right
    I've used many electric boilers and found them to be crap!
    I have been using only Electro for my electric boiler applications for about 3 years now and have had no problems.
    Available with: outdoor reset
    staging elements.
    For use with duel fuel setups
    QUIET ELEMENT STAGING!!
    I don't work for them just really like them after using other brands!
  • EricAune
    EricAune Member Posts: 432
    Thermolec
    I saw a press release late last year for a 3Kw & 5Kw staging mini boiler from Thermolec.  I have been using a variety of their models for years.  Stainless, ODR, built-in breaker, east to repair if needed.  Consider parts availability locally before going to something new.
