Small Electric Boilers?
Bart Vaio
Member Posts: 56
I used to use the Laing EPR heaters for small loads 2-12 KW. It seems they have discontinued that line, are there any alternatives out there you guys know about? Ideal load is 3Kw, any suggestions?
Laing EPR
The last I heard is the the EPR units are currently being upgraded to an ECM pump/motor and going through UL or similar third party testing. The tenative availability is this fall. They will be distributed through the B&G sales chanel. I believe the older induction motor units are still available. You may try to contact Laing via there web site and pose the question. Good Luck Kevin.
amy.flores@itt.com0 -
Same info I heard
from the B&G folks in Canada. B&G, or ITT has partnered or bought out Laing,
I did see a Laing booth at the ASES solar show a few weeks ago, however.
I think B&G has some interesting plans for that pump line.
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Electric Boiler
Argo makes a nice electric boiler.
email me at eckrobert@rcn.com if your local wholesalers can not get them for you I work for a Plumbing & heating wholesaler and we can ship them direct to you
thanks bob0 -
Electric Boiler
thanks bob0 -
Electric Boiler
thanks bob0 -
Electro Industries
out of Minnesota builds a nice one. Also the Thermolec out of Canada.
And so does
Slant/Fin....LOLThere was an error rendering this rich post.
Hot Rod's right
I've used many electric boilers and found them to be crap!
I have been using only Electro for my electric boiler applications for about 3 years now and have had no problems.
Available with: outdoor reset
staging elements.
For use with duel fuel setups
QUIET ELEMENT STAGING!!
I don't work for them just really like them after using other brands!There was an error rendering this rich post.
Thermolec
I saw a press release late last year for a 3Kw & 5Kw staging mini boiler from Thermolec. I have been using a variety of their models for years. Stainless, ODR, built-in breaker, east to repair if needed. Consider parts availability locally before going to something new.There was an error rendering this rich post.
- 129 Chimneys & Flues
- 122 Geothermal
