Dehumidify mode on mini split
I have a Samsung inverter mini split that works really well, but I have a question.
What takes place on the dehumidify mode? I thought that it was just slowing down the fan speed but it has to be more than that because I can manually put the fan on low in the cool mode and it doesnt remove near the amount of water it does on dehumidify.
  • Techman
    Techman Member Posts: 2,143
    dehumidify
    Tony,it also slows down the comp for a colder evap coil.
  • TonyS
    TonyS Member Posts: 849
    Techman
    How does slowing down the compressor make the evap colder?
  • Dave Yates (GrandPAH)
    Dave Yates (GrandPAH) Member Posts: 281
    dehumidification mode
    Sensors are utilized to monitor air temp, coil temp, and humidity. The objective is to extract humidity while maintaining room temp within 2F. The compressor is either slowed or briefly run to inject just enough freon to keep the evap coil below the dew-point while the fan is run at low speed. Normally this means a short run-time for the compressor with several minutes of air-across-the-coil before the compressor injects another 'mist' of freon.
