Airtrol and Expansion Tank Maintenance
splats
splats Member Posts: 1
What should I be doing maintenance wise with an old steel expansion tank with a B&G Airtrol fitting on the bottom of it and a boiler drain also on the bottom of it. I have not tried opening the drain yet, but the tank sounds empty when tapping on it.
I am going to be draining the system down to do work on the wet side. Should I have the shut off valve to the expansion tank in open or closed position when refilling and then open it when the system is pressurised? Do I need to be concerned with making any adjustments to the airtrol fitting?
Any input on proper procedure will be greatly appreciated.
  • If you are going to drain
    the system for repairs, may as well drain the tank too. So leave all the valves open.
    In my 30+ years I have NEVER been able to tell how full a tank-is by tapping on it.
    Drain-it, and you`ll know,,, those B&G Airtrol fittings are great though. no adjustment necessary, except for the initial fill.
    BTW- If you`re going to do that I would also run some Rhomar system cleaner through everything too,, can`t hurt. :-)
  • mjcromp
    mjcromp Member Posts: 57
    tap tap
    I can tap out a standard expansion tank to make sure the bladder is not busted or out of air but those old ones are much harder to tap out.
