SNOW MELT SENSOR
SNOW_MELT_STEVE
Member Posts: 1
Has any one have any ideas for a sensor that will turn on a snow melt roof application, The Tekmar 090 and 091 driveway snow melt sensor wont do the job..
snow melt sensor
There are different manufacturers that make ones designed to mount on a pole, sort of a funnel type thing if I remember correctly, can't recall the brand though maybe someone else can? The tekmar should work in this situation, you would just have to build a box or something for it to sit in and mount it sticking out of the side of the house or on a pole. Ask tekmar they might have a suggestion or two.0 -
SNOW MELT SENSOR
Environmental Technologies is the company that makes the "mast-mount" sensor. thsi sensor is compatible with Tekmar Controls if that is your inclination.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
