Heat Pump Installation
DanB214
Member Posts: 1
I had a 2.5 ton 15 SEER split heat pump installed 10 months ago in a 1500 sq. ft. ranch home. It has caused some problems, the latest is that the inside coil froze up and the outside unit was 2 lbs. short on refrigerant. The tech came out and said that the return needed to be bigger...when the installation was done (replacing a 20 year old unit), the only return was a 12 x 20 grille at the bottom of the unit, which sits in the hallway behind a louvered door. The tech recommended putting in a 20x20 return right across the hall from the unit, where there is a closet on the other side of the wall. Does this make sense? Also, was the original installation done poorly with such a small return? It seems to me that 240" sq. is way too small a return grill for a 2.5 ton unit. Thanks!
Personally.
I'd start to deal with the size of the door louvers as well as the return size. Keep the door open a few days to see if the coil still freezes up.0 -
and...
find out where the leak is that let those 2 pounds out and make sure it is fixed!0
