Tekmar 371
dbefus
dbefus Member Posts: 2
My tekmar 371 died. We had several power outages. I have checked the fuse on the circuit board and it is good. Any Suggestions?
  • dbefus
    I should add...
    Yes the power is on.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,872
    Put your nose right next to the control.....
    and take a whiff. Does it smell of acrid smoke? If yes, it's fried.
    Solid state electronics do not like surges, man made or otherwise. I've seen holes the size of a silver dollar burnt through boards on tekmar before.
    Sorry I don't have better news for you. There are no internal fuses or circuit breakers.
    ME
  • Jean-David Beyer
    Surges, fuses, and solid state electronics.
    When I used to design electronic equipment, we had a saying: the transistor acts to protect the fuse. This was because a transistor can be fried by a one microsecond surge, while a fuse tends to take much much longer to blow. A fuse can perhaps protect against long-term overloads, and is a good safety measure for a system to protect the building it is in, but it will almost never protect the electronic equipment itself. For that you need good wiring and a suitable surge protector.
