If our community has helped you, please consider making a contribution to support this website.  Thanks!
Amtrols not so "smart" control
                    AntnyC
                    Member Posts: 11
                    I have a client with a Amtrol 41 gal indirect equipped with a Smart control. We went through 2 controls in 2 years, at $200 a pop for the part this is getting ridiculous! Can I substitute a low cost thermostat for this control? Any suggestions on specific items? Thanks
            get rid of it
and use the retro-fit control from Amtrol. Old style aquastat used on the "Z" models. I have a mountain of failed Smart controls. The first generation of them lasted, as they "revised", they lasted a year or two if you were lucky. Check into the retro, and be done with it0 -
            reply
I thought of that, but the smart control has a thermistor thats shoved way up inside the tank while the old type dial control comes with a bulb/ capillary tube thermostat with only a short section of tubing. Do you think it will work effeciently sensing the temp from the bottom of the tank? Thanks for the feedback0 -
            adjustable
They are both adjustable. If you notice, there are red and blue marks on the lead for the smart control. You should never bottom out either control sensors into the well. You will run out of hot water for one. The capilary should be about 3/4 way in there on both. The retro has a compression type fitting to keep the insertion depth from changing, They come with instructions also0 -
            I"ll check it out
Thanks bill2.0 -
            anytime
good luck Antny0 -
            I will be doing the same
I have one that just cooked the 4th SMART control in 7 years, Good to find out I can go back to the old stat0 -
            I can
get you guys the part # if that'll help. Not that much $$$, and the old aquastat has more than proven it's longevity .My Amtrol in my own house is 25 years old with no problems. Original coil and control. Let me know if I can help with the part #.0
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
