nycbricks
nycbricks
Member Posts: 7
I have a smith 19-7 with a carlin 702 crd that I do not use in the summer. What is the best thing to do with the water in the boiler
Drain it
Fill the boiler up to the pop saftey and shut the burner off
or
fill up and keep the burner on and the aquastate at lowest setting?
Drain it
or
Why do you have an aquastat if you do not use the boiler?
does it provide hot water?Cost is what you spend , value is what you get.
cell # 413-841-6726
nycbricks
I used to use it to make hot water but the tenants supply their own hot water now.0 -
Then remove the aquastat.
as far as flooding or not that is your choice. some people say yes I am always concerned that it is forgotten and the boiler is run in a flooded state.Cost is what you spend , value is what you get.
cell # 413-841-6726
nycbricks
Again
Should I fill the boiler up to prevent oxidation or drain the boiler
Should the boiler be turned off untill I need it for steam or keep it running at a low temp setting to keep the boiler and burner lubricated0 -
flood it
I would shut it off and fill it.0 -
nycbricks
thank you toilburn0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
