Water Heater Check Valves
Member Posts: 4,470
Most water heaters that I install come with check valves on the cold water nipple to prevent thermosiphon. I always take them out because they tend to cause harmonics in the piping that drives my customers nuts.
It seems like a good idea except for the performance failure of the component.
What do you guys do?
If the piping.....
is insulated a thermosiphon is not a bad thing.... most all my customers like getting hot water faster...0 -
Some of...
... the newer heat traps have rubber flaps instead of the noisy/evil little balls that older heat traps had. The new style is quiet. The old way of getting there is to form a loop using fittings or a long flex line to make a non-mechanical heat trap. It's really quiet!
Yours, Larry0 -
Never seen a check...
Is that a California code ? I never seen one come with a hot water heater .There was an error rendering this rich post.
Big Ed
They are integral to the cold inlet nipple. Any water heater with nipples already installed or packaged with the water heater most likely has them.There was an error rendering this rich post.
Check
Is the check a new Federal conservation code ?There was an error rendering this rich post.
- 110 Chimneys & Flues
- 982 Plumbing
- 387 Solar
