Water Heater Check Valves
Most water heaters that I install come with check valves on the cold water nipple to prevent thermosiphon.  I always take them out because they tend to cause harmonics in the piping that drives my customers nuts.
It seems like a good idea except for the performance failure of the component.
What do you guys do?
  • kcopp
    kcopp Member Posts: 4,707
    If the piping.....
    is insulated a thermosiphon is not a bad thing.... most all my customers like getting hot water faster...
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,171
    Some of...
    ... the newer heat traps have rubber flaps instead of the noisy/evil little balls that older heat traps had.  The new style is quiet.  The old way of getting there is to form a loop using fittings or a long flex line to make a non-mechanical heat trap.  It's really quiet!
    Yours,  Larry
  • Big Ed_4
    Big Ed_4 Member Posts: 3,553
    edited April 2010
    Never seen a check...
    Is that a California code ? I never seen one come with a hot water heater .
  • EricAune
    EricAune Member Posts: 432
    Big Ed
    They are integral to the cold inlet nipple.  Any water heater with nipples already installed or packaged with the water heater most likely has them.
  • Big Ed_4
    Check
    Is the check a new Federal conservation code ?
