Leaking hot water
mor
Member Posts: 41
In a gas boiler older than you and I, the hot water coil seems to be leaking into and filling the steam system. Plan to bypass it. anything to watch out for?
make sure it is caps with a relief valve
not a plug or cap as the leak could corrode shut and create a closed loop with no where to expand.Cost is what you spend , value is what you get.
cell # 413-841-6726
replacement coil?
i did find a place online once that had replacement coils for my Fiztgibbons 400 .. have you looked into a possible replacement? .. in fact, I've found it again: http://www.tfi-everhot.com/pdfs/TFI_TanklessCoils.pdf1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Thanks.
1 Relief valve on the outlet I assume. thanks for your response. MB0 -
Thanks
actually at this time they just want to waiti out the the boilers life span. [I guess till it breaks on a weekend in January]. Thanks for the help MB0
