Press/Temp ; Temp/Press Charts
Techman
Member Posts: 2,143
There was a time when a P/T chart [#1] was just a P/T or a T/P chart , with pressure,temp,and vacuum readings.Then out came a P/T chart [#2] with temp, vacuum,vapor[psig] and liquid[psig] readings and then another chart [#3] with press,inches mercury below atmospheric,dew point and bubble point readings.Care to explain the what for's and why not's?
Professor
when there are 100 viewers with 0 replies I am going to ask for your knowledgeable input.I can feel your twitching fingertips moving, thru, the cosmic energy waves!0 -
True to my word
Hi Professor ,I'm back!!!!!!!!!!! With 100 viewers and no advice given I'm looking to your astute knowledge to fill in the blanks in my mechanical brain. If you have the time please tell US's about the different P/T charts. Thanks!0 -
Refrigerants
with all the changes of refrigerants it's a little hard to understand all of this liquid and vapor pressures from what I can gather when charging a system with r- 400s and r-500s refrigerants you need to recharge in a liquid state instead of a gas If you don't you will make a permanent change in the blend to deviate outside its tolerances of the design . Forane Refrigerants has a nice web site and explains all of this www.forane-us.com
Good Luck Dom0
- 123 Chimneys & Flues
