wet return line leaking
tony_19
tony_19 Member Posts: 30
hi everyone
i wanted to know if it is ok to replace a wet return line that was original black pipe with copper. i was told that it could be done. will it have any effect on the system.
thank you
tony
    Steamhead Member Posts: 18,207
    That's
    the one place on a steam system where it shouldn't be a problem. Some prefer black pipe here though, but as long as steam doesn't enter it you should be fine.
    Consulting
  • tony_19
    thank you
    thank you
