wet return line leaking
tony_19
Member Posts: 30
hi everyone
i wanted to know if it is ok to replace a wet return line that was original black pipe with copper. i was told that it could be done. will it have any effect on the system.
thank you
tony
thank you
tony
That's
the one place on a steam system where it shouldn't be a problem. Some prefer black pipe here though, but as long as steam doesn't enter it you should be fine.All Steamed Up, Inc.
Consulting0 -
thank you
thank you0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
