tekmar control 360 boil target blank
m206718
Member Posts: 1
i have been having heat problems. the burn stops firing and the error light is not on. when i cycle through the control items the boiler temp is well below the setting and the boiler target is three dashes instead of the number. when i enter the setting menu the target is set. the only way to fix it is to cycle the power to the unit but the fix only seems to last a day or two. if anyone has an answer that would be super
power?
How are you powering the control? I once solved an erratic control by giving it its own source of power. MB0 -
power?
Mix Target - - -
The mix target shows three dashes when there is no mix demand signal on terminals 1 & 2, or if the outdoor temperature exceeds the Warm Weather Shut Down (WWSD) setting.0 -
tekmar 360
You need to contact your local tekmar rep or call tekmar @ 250-545-7749.
Be prepared to explain your wiring and settings. They are only as good as the information you give them.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
