boiler size
captpete12
Member Posts: 11
i have a 12 apts. in one building the boiler is a burnham v 2009a oil fired steam a contractor came out to give me a price on a burnham gas fired k5006 steam boiler. my problem is the oil boiler is 2500 sq. ft. of steam, the new gas unit they want to give me is 1004 sq. ft. of steam someone please help me understand this one. i thought gas was less/ than oil
Apples to Oranges,,,
NG is not as hot a flame as oil, so that`s a factor(not in his favor), but
did he perform any kind of H/L for the units as they are now?
Perhaps you don`t need to satisfy HUGE rads completely across all the sections to meet the load requirements nowadays, if it`s an "old system" building upgrades definitely reduce the needed load,,, but again, that can ONLY be calculated by a proper H/Loss room by room.
Tricky stuff if you play-it that way,,,, but it is accurate!0 -
See my answer
in the thread you posted under Strictly Steam.All Steamed Up, Inc.
Consulting0 -
Good Advice Frank (old friend) ;-),
I keep forgetting about the other WALL categories Dan has,, :-)0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
