What are my options if gas is in the building?
AL the Plumbah
Member Posts: 7
Do I stay with oil or go for the rebates on gas? Thinking about a tt prestige exellence, or weil cgi, or weil wgo oil w/ tankless.
gas would be ...
convenient. What type of emitters are there? Cast iron rads? Finn tube? If cast the Gas condensing boiler would be a plus. Start w/ a heatloss and then you can see if there needs to be 2 boilers or if 1 would work. Also if the radiation is "over sized"... a plus for gas condensing..... If the chimney is as old as the boiler(s) pretty good chance that it is either not good or it needs to be lined. A direct vent would save you that cost.... kpc0 -
cast iron rads...
Cast iron rads. Your right about the chimney, I want to avoid it. Do you have any sugesstions to name brands? 65,000 btus but need hot water so I was hinking a 45 gallon superstor.There was an error rendering this rich post.
1 or 2 zones and metering
If these are for seperate units and you want seperate billing for each unit, you could put in a single boiler with zone controls and install btu meters on each unit (and maybe hot water) to divide up the fuel usage.There was an error rendering this rich post.
there are a bunch...
Personally I would Look @ the ONEX by Embassy... and the Triangle tube products. (solo and Excellence)0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
