What are my options if gas is in the building?
Do I stay with oil or go for the rebates on gas? Thinking about a tt prestige exellence, or weil cgi, or weil wgo oil w/ tankless.
  • kcopp
    kcopp Member Posts: 4,711
    gas would be ...
    convenient. What type of emitters are there? Cast iron rads? Finn tube? If cast the Gas condensing boiler would be  a plus.  Start w/ a heatloss and then you can see if there needs to be 2 boilers or if 1 would work. Also if the radiation is "over sized"... a plus for gas condensing..... If the chimney is as old as the boiler(s) pretty good chance that it is either not good or it needs to be lined. A direct vent would save you that cost.... kpc
  • AL the Plumbah
    AL the Plumbah Member Posts: 7
    cast iron rads...
    Cast iron rads. Your right about the chimney, I want to avoid it. Do you have any sugesstions to name brands? 65,000 btus but need hot water so I was hinking a 45 gallon superstor.
  • 1 or 2 zones and metering
    If these are for seperate units and you want seperate billing for each unit, you could put in a single boiler with zone controls and install btu meters on each unit (and maybe hot water) to divide up the fuel usage.
  • kcopp
    there are a bunch...
    Personally I would Look @ the ONEX by Embassy... and the Triangle tube products. (solo and Excellence)
